diesel_lv
I'm going to try another set of fans on my '67 Coronet, 496. I'm in Fort Mohave AZ where our summers are regularly over 115 n often see 125. These new fans pull 40 amps at start each and then run at about 22 amps. I've got a serpentine pulley setup w a 140 amp alternator. My question is, should I run my power wire ro my relays directly from the alternator? Reason for asking is thinking about how much amps would be going through the relay just below the firewall wiring bulkhead. Thanks in advance.
