Electric Fuel Pump Location on 69 Charger
68n69 Charger
12:12 AM
Texas
Good afternoon,
I am looking to install an electric fuel pump to assist with starting the car after sitting for a spell. Can anyone share pictures of their installation? I bought an Edelbrock fuel pump 17301 4-7 psi.
Thanks in advance!
That's pretty neat. A lot will depend on your exhaust system.
Good afternoon,
Thanks in advance!
For an inline “booster pump” like that, I would suggest you try to mount it inside the passenger frame rail and splice into the stock fuel line. Closer to the tank (back of car) the better
Good afternoon,
Thanks in advance!
If you're running an LS motor....it should bolt directly to the block. :p
After the fuel bowls are filled, will the mechanical pump pull through the electric pump, or do you need to keep it running all the time?
Not a 69 B body. My install on my 65 Coronet with a Carter. I use a momentary push button switch under the dash before cranking-key on to prime. Works well.
Mike
