kp72
I got most of my gauges in the GTX today. I went with Auto-Meter ProComp, installed on a custom instrument panel. I have all the senders and wires run towards the instrument panel, but I'm stuck at one place: Where do I pull power from? Which wire coming off of the ignition switch is the "outgoing" power? I have to cut the old wires going to the light switch connector anyway, since I'm switching to toggle switches, is that power wire big enough to handle all the gauges?
Maybe it will help if one of you wiring gurus can give brief description of the three basic parts of the stock fuse block... one is switched power, one is always hot, the other is...?
Also, I am switching from an ammeter to a voltage gauge. What should I do with the wires that used to power it? Looks like they just have to be connected, does it matter where? Can I use that for a power source?
I am planning to get all this stuff running, then make my own harness from scratch, unless I find something else suitable (American Autowire?). I'll post pics soon, once I get this thing in place.
