SOLD electronic ignition 1973 340 small block distributor 3656771
bbrroowwnn
11:28 AM
Drums PA
Feedback: +0 / =0 / -0
OEM 1973 electronic ignition 340 small block distributor #3656771 ....date code 38 2 so I think that it was made the 38th week of 1972...Not sure on that though....Definately from a 1973 340 though....could use bushings as there is some side play in the shaft........40.00 + shipping....postal M.O. works for me
Yes, that distributor is for a 1973 dodge or plymouth, and its the same number that is on my 340. Here are the specifications if it helps you to sell it.
Mechanical Advance
Advance starts 0.5-3.5 degrees @ 600 RPM
Intermediate advance 8.5-11 degrees @ 1000 RPM
Full Advance 13 degrees @ 2000 RPM
Vacuum Advance
Vacuum to start plunger 9 psi
Max advance 10 degrees at 12.5 psi
Mechanical Advance
Vacuum Advance
thanks for the info
