Enclosed Trailer Flooring
dam130af
10:22 PM
Nebraska
Just seeing if anyone has used any kind of Herculiner etc on their enclosed trailer floor. I am picking my trailer up next month and am getting plans figured out. I don't have alot of extra weight to play with.
I just did my small trailer I use for karting, 6x12 v nose.
From what I read, those bed liners won't adhere well to plain wood, if that's what you have.
What I did was to use Thompson's on the underside of the plywood, 2 coats, then one coat to the floor (inside). Then you have to use an enamel paint over the Thompson's on the floor. The depot sells a non slip additive I used that will keep you from slipping on the ramp and floor. On the underside I did spray bombs of undercoating....
Hope that helps....
