- 1:17 AM
- Apr 13, 2012
- Granite Bay CA
I have dealt with some type of oil leak in my 440/493 since the first build in 2004.
The bottom of the timing cover sits a few thousandths of an inch above the block. I first had a stock steel cover, then a chrome one. Now I have a painted steel one again. Several months back I changed to the gasketless windage tray from Jegs. No leaks on 3 sides but it still weeps a bit at the timing cover area. It was just recently that it occurred to me that despite several attempts to seal this bottom end, each effort resulted in leaks in the same spot.
The timing cover is positioned by the dowel pins. It is held on by the bolts.
I'm wondering if the holes for the dowels can be filed slightly to allow the cover to be positioned slightly lower, effectively being at the same plane as the block. One concern is that the movement from the current position might result in the balancer snout being off center, causing a bigger leak. Maybe the balancer is off center now, huh?
Have you dealt with this before?
I'm building the 383 for my "Jigsaw" Charger and am hoping to keep the oil on the inside of this one.
