Texas charger 73
Ok i started getting my dash ready to remove because I'm doing a standard to Ralley conversion and nacho said it is easier to just pull whole dash.assembke.,wire and re install dash, well my.issue is in the point of removing and in hooking the multi point plug behind fusebox going into firewall instead of what I thought was going to be a big plug in turn is a bunch of different plugs. Wowza. I'm not sure what plug goes where. Does anyone have an exploded view of it all hooked up or have a reference other than just a wiring diagram. Also I'm fixing to buy a complete harness for a 400. Can I use that engine harness on a 318 motor. I'm sure some wires are different bit can't be too many. All help is appreciated?
