FOR SALE Excess parts from my 65 Corinet
ckessel
1:33 AM
Los Osos Ca.
FFI stage 3 box. Need to be re-sealed. Has low miles but leaked since new, just dealt with leaks. $200
Disc brake and spindle units. Spindles most likely E or A body units. Pin type calipers. 10 1/2" rotors. $200 pr
Up to 69 b-body front sway bar with frame brackets. $50
4 15x8 Weld dragnet wheels. 0 offset. 235/60r15 and 275/60r15 cooper tires. 80+% tread. $150 each
Original fuel tank, no leaks. Has 3/8" sender. $75
Coronet 500 steering wheel and horn ring. One small crack in wheel. Black. $200
Coronet 500 center console with shifter. Needs cables. $600
Coronet 500 instrument cluster and dash trim. Gauges work. $400
Coronet 500 a/c system under dash. No engine compartment plumbing. Have only whats under dash. heater core leaks, blower motor dead, have controls, ducts, expansion valve. $500
Old school Stewart Warner stage 3 tach that uses the big resistor in the engine compartment. $250
My contact information is Carl *******NO email addresses OR telephone numbers allowed as per site rules - Use the Conversation feature for contact****** Prices do not include freight if shipping is required. I work full time so I will use whatever is most convenient to ship and may not be the cheapest.
