turbo36
First the car specs: 1965 Belvedere II, 383 mild mod, 3 core radiator with a shroud. I'm running a Hayden 2765 fan clutch with the 5 blade Mopar Performance fan, 180 degree thermostat and high volume water pump., it seems to not be working properly. At 75 degree air temp the coolant temp will run up to 215 at idle, 205 at moderate cruise speed of 35-40 mph but drop to 200 at a higher cruise speed of 55-60 mph. It appears to me to an air flow issue through the radiator.
If I stop the engine when it is in the 210-215 range and spin the fan by hand it freewheels with very little resistance . Is this normal operation?? My understanding is the clutch will slip until it get warm and then firm up.
thanks, Bob
thanks, Bob
