Fan shroud question
Orange71SE
5:09 AM
Phoenix, AZ
hi guys, there's a guy in my area selling a 66-7 fury fan shroud for $25. My 1971 charger dosen't have one and all the shrouds I've seen are more than I'd like to pay. So my question is, will the 26" shroud fit on my '71 b-body?
If your radiator is original in your 71 then, no, it wont fit. C body shroud is 3 holes per side and mounts with stud/nut. 71 shroud is 2 per side and they are a screw that holds them on, not the nut/stud.
I'm not particularly looking for stock bolt on. would it be possible to just kinda mock it up and make it fit.
You might be able to fabricate some sheet metal brackets that would mount to the radiator and then be able to attach the shroud??
For $25 I'd give it a try.
Shrouds for my 62 are metal and used oem are hundreds of dollars, aftermarket are not any cheaper. I bought a 63 C body shroud for $120 and cut and welded it to fit.
