FUNNY!
YY1 just posted Thursday the average prices of "center pieces" and listed them in sequence...
Another words:
3:23
3:55
etc...
I'll find the post for you....
FUNNY!
Another words:
3:23
3:55
etc...
Here is the POST by YY1
I've had really good luck buying used center sections. In nearly 30 years, I've bought about a dozen, and only got one bad one, and I suspected it needed refreshed when I got it (bearings are stiff). Look at the gears carefully for evidence that it's sat out in the elements, or has been dropped or run set up improperly. Spin it by hand while paying attention to the feel- no binding, or stiffness- no wobble or play. Most likely issue with used (and hardest to check) is slipping SG, although for the price of a used unit and a rebuild kit (clutch only*) you're usually money ahead vs buying a new SG unit.
Chunk pricing has been relatively flat, but lately there's been a lot of pie high asking prices, and very recently I'm starting to see asking premiums for clutch units (vs cone).
Here's what I've been tracking-
(all SG)
2.94- $300
3.23- $350
3.55- $400
3.91- $450
add $50 for 742 case and $100 for 489 case.
You will likely have close to $1000 buying things new and having it setup.
Knock a couple hundred off that if you can set it up yourself, but you'll need dial indicators, a spanner, and maybe a spline holder device.
I wouldn't mess with the bearings unless you know they are bad. Usually they'll tell you (via howl) well before causing any damage.
A whole housing assembly for 71 and up B will be a challenge. Those are the hardest ones to find (esp SG)...and you've already got one!
An E body housing is about 3/4 inch shorter (and 5/8 closer perches), but should work.
You're still up against the odds though on it having an SG and the gears you want.
They made a lot of 318 E bodies with 2.73 open gears (although they pretty much all had the 489 case).
Again, this research was performed by a fellow team member YY1
If you think it helps you, send him a PM and thank him AND send him a thanks ....
