dfarmercse
- 12:52 AM
- Apr 30, 2011
- Lake Charles, Louisiana
Can you replace the studs in the finish panel?
Dave F
Dave F
I wouldn't epoxy the screw in as this would make it very difficult to ever take it back off in the future. What you could do though, is epoxy a #10 macine screw minus the head into the shallow hole that you carefully drilled into the panel. Depending on how thick the panel is at that point you might be able to drill and tap. using a bottoming tap or a standard tap that you grind the tip flat so that you can thread to the bottom of the hole you drilled.
