- 1:03 AM
- Apr 13, 2012
- Granite Bay CA
I used to be a confident guy in terms of working on cars. I was a Chevy guy for many years and I had the support of the aftermarket to bolster my efforts. In 2000 I bought the Charger and had to develop my own support system to work things out.
I'm usually pretty decent at parts replacement. I can weld, do bodywork and paint. I've rebuilt engines and performed some minor transmission repair, but for some odd reason, the 727 in my Charger has really tested my abilities !
I had the trans out a month ago to modify the stall of the converter. After putting the trans back in I have had a pesky leak near the dipstick tube. I first thought that the pan gasket was damaged, so I replaced it with another Mopar plastic/rubber gasket. It still leaked. I tightened the bolts a little more. It still leaked. I pulled the dipstick tube and replace the O ring. It still leaks. I have headers and 1 inch torsion bars so getting a direct view of the origin of the leak isn't easy. I assume that the leak could still be from the dipstick tube, so I have one more idea that I read from a Moparts member. I'll drain the ATF, remove the pan and dipstick tube and clean everything. I'll smear sillcone inside the trans case where the dipstick tube fits, then smear some around the tube and O ring. I'll let it sit a day to set up, then put the pan back on and refill the ATF. If this doesn't fix the leak..... THEN what?
