From pwr steer to man steer
Virg464
5:35 PM
Mid Michigan
I have a manual steering box for my 66 coronet that I want to install, the car came with a pwr steer unit. My question is, is this a nuts and bolts only swap? Or...will I need a different steering shaft, and or other things? Thanks.
You will need the upper shaft and possibly the coupler housing along with the correct pitman arm.
Mopar used to make a billet adapter that turns it into
a 15 Minute job. Possible they still do?
Please use the PM system for that. Thanks
Just get the adapter. It plugs into your coupler and extends to the manual box. No BS. So much better than hacking things up.
Power to Manual Steering Adapter
the pitman arm is the same as long as they are both the smaller diameter spline on the box that your 1966 came with.
