front axel
67 gtx cov
10:24 PM
spring city pa
I know this is not a truck forum I tried the dodge forum got nothing I need to decode the tag on the front rear of my 94 2500 don't know if is a dana 44 or 60 can any one help thanks
It will have a 60 or 70 casted into one of the center web's . Post a pic of the tag and rear. We will hook ya up !
the id plate reads top #52068705 bottom# 4 10 610440-2 thanks
drivers side web 60f pass side 44880 with a c above I do have the ring gear # thanks
A diesel would have a 70 in the rear......but would a gas rig have a 70?
This might help.......
AXLE GEAR OIL
Front Axle lubricant is any SAE 75W-140 synthetic gear oil that meets MIL-L-2105C and API GL 5 quality specifications.
Rear Axle lubricant is any SAE 80W-90 gear oil that meets MIL-L-2105C and API GL 5 quality specifications.
Axles intended for heavy-duty or trailer tow should use SAE 75W-140 SYNTHETIC API GL 5 gear lubricant.
Rear Limited slip Trac-lok and Vari-lok axles require Chrysler Friction Modifier 4318060.
Axle Application Engine Transmission Axle Oil Capacity Friction
modifier
Front 1500 4WD All All Dana 44 (216) 4.8 pts. NR
Front 2500/3500 4WD All All Dana 60 (248FBI) 8.5 pts. NR
Rear 1500 All All Corporate 9.25" 4.5 pts. 4 oz
Rear 2500 2WD V8 All Dana 60 (248 RBI) 6.3 pts. 6 oz
Rear 2500 4WD V8 All Dana 60 (248 RBI) 7.0 pts. 8 oz
Rear 2500 2WD V10, Diesel Automatic Dana 70 (267 RBI) 7.0 pts. 8 oz
Rear 2500 4WD V10, Diesel Automatic Dana 70 (267 RBI) 7.5 pts. 8 oz
Rear 2500 2WD V10, Diesel Manual Dana 80H Rear Axle (286RBI) 6.8 pts. 8 oz
Rear 2500 4WD V10, Diesel Manual Dana 80H Rear Axle (286RBI) 10.1 pts. 10 oz
Rear 3500 2WD All All Dana 80H Rear Axle (286RBI) 6.8 pts. 8 oz
Rear 3500 4WD All All Dana 80H Rear Axle (286RBI) 10.1 pts. 10 oz
