Front Brake line
Robert Schaad
9:24 PM
Replaced the complete front brakes on my 72 Satellite, disc set up. Did not change the rubber brake hose however. Had new ones but got lazy. The rubber ones were bad and caused the rotors to heat up and screw up my brand new rotors. If you go to all that work to change brakes like I did, replace the rubber lines.
:BangHead:, yep I need to do that on my Bee
When I'm searching for certain brake problems that's the first thing on the list. There is no telling how many times I have found the rear hose bad, but the fronts suffer the same fate.
