Front Break Line Pressure
Endangered Species
1:50 AM
NW Pa.
What is the ideal front Break Line Pressure for a Mid 60's Nostalgia S/S car.
Right now mine is 550 on the right and 600 on the left. Not sure what the ideal pressure on the front should be. I didn't play around with the proportioning valve yet because I'm not sure what PSI I want on the front.
You can't have different pressures from one port on the master cylinder. Pressure output from the master cylinder is dependent on how much pressure you apply to the pedal.
Mike
