Front directional bulb changes how to, on 72
MikeyT
4:33 AM
Wisconsin
Hi all,
Is their a trick to getting out the directional bulbs, under the grill? I need to change one, and undid the screws holding the amber lense in place, but couldn't get it to pop out, and I didn't want to break it either.
Any help would be great!
Thanks in advance.
Mikey
could be just road grim holding it closed.try taping on it with small rubber mallet or the handle of a screw driver.
have you removed the top screw which holds the top housing tab to valance ? I allways do, for easier remove of lense. You can pull it out in fact from that screw hole provision
Thanks Nacho, I did undo that screw but didn't try to pull it out thst way
way easier that ( and safer ), than pry it out between lense and valance. Simply use the hole to pull it out with your finger
The lens tends to stick to the rubber gasket. Just takes a little force to break it loose.
