WTB Front Fender Body Plugs
JimKueneman
8:21 PM
Sonoita, Az
Feedback: 2 / 0 / 0
1968 and probably 69 Coronet. If you open the hood and look down in front of the radiator support on each side the outer headlight and marker light harness goes though a hole in the inner fender to make its way to the backside of the outer fender. That pass through has special body plugs that are split so the wires can be passed through the plug as a grommet. They at odd sized and larger than anyother plug. I need one but would take a pair.
Jim
These are to ones your referring to right?
I do not think I have any but a measurement would be helpful..
View attachment 404010 These are to ones your referring to right?
That's them. I have one it's just that the fender was replaced way back in the 70s and the replacement fender didn't have that hole drilled in the body shop just ran the wires around the bottom. I wanted to make it right again
Smart thinking....it was there for a reason! Try national moparts in Canada to see if they have a car to pull that from, possibly...
