Front Suspension Install Help..
dodge68charger
6:36 AM
Washington
I'm Installing The Steering Center Link And Tie Rod Ends In My 68 Charger. The Car Has No Steering Column In It.. How Do I Go About Installing Everything. One Tie Rod End Is Maxed In and The Other Maxed Out. How Do i Know The Steering Box Is Centered So I Can Get Both Tie Rod Ends Even and the Wheels Pointed Straight. Thanks
ha ha i thought i was the only one . i just made sure tie rod ends were even on both sides when i had them off. then i centred the steering box by dividing the turns in half ,( if you go on carid.com and look up your box it says how many turns it does so devide thatin 2 ) on my belevedere the steering wheel to column has a double spline so it can only go on one way.you cant repostion the wheel like other cars.good luck
Measure the old ones you took off keep left and right separate you should be very close at that point
No Old Ones To Measure. I Had My Steering Box rebuilt and They Took Off The Pitman Arm.
I Will Try The Counting Turns Method..
