Fuel line?
popslavaz
2:47 PM
Channahon IL.
Need new hard fuel line for my '71 383 w/4 bbl. avs carb. Book shows single line and two piece line. Which line or lines have you out there used? (pump to carb)
POPS
I'm not sure..... but isn't the 2-piece fuel line for cars with the vapor separator (440 I think) or maybe California emission???
I'm not sure either, that's why I suggested inlinetube. I'm pretty sure they can reference the specific need.
The line you need depends on the fuel pickup and fuel pump. There's two kind of OEM style pickups.
The 5/16" line pickup has no return.
The 3/8" pickup has a 1/4" return line. You'll need a fuel pump with a return outlet. Only the fuel line goes to the carb.
The vapor line runs from the tank vent to the charcoal filter then from there to the purge valve then to the carb. The AVB might or might not have an EVAP inlet. You can bypass that mess, if you want, with an old school vented gas cap.
Per Inline tube:
1971 Satellite / Roadrunner / GTX Fuel Lines
PRF7101 Main Fuel Line 5/16" 1pc, OEM Spec
PRF7102 Main Fuel Line 3/8" 1pc, OEM Spec
PRF7103 Fuel Return Line 1/4" 1pc, OEM Spec
PRF7104 Fuel Vapor Line 5/16" 2pc, OEM Spec
Coil of hardline and a bender, fits every car lol.
I am a retired Union Ironworker,bent a lot of round steel but no hollow stuff.Do not want to use all the EPA recycle vapor stuff, just want a steel line to go pump to carb. Got some great posts to put me in the right direction. Thanks Again POPS
Thanks,72roadrunner gtx. Looked up there web site got the phone number. Will get it today. Thanks Again
POPS
