Anyone ever purchased the Golden Star sending units from JEGS?  Curious if any good or what others have used.
			So any suggestions? Rebuild or ?In general, it seems the aftermarket sending units aren’t accurate
I have one from Vans in my charger and it works fine.
					vansauto.com
				K, thanks. Happen to know the manufacturer for these?I have one from Vans in my charger and it works fine.
I searched for an old factory one that worked & found oneSo any suggestions? Rebuild or ?
No sorry I don't.K, thanks. Happen to know the manufacturer for these?
Great if you don't mind extensive modification to a stock tank...Holley has a new “floaters” sending unit. Here is the blog on it. https://www.holley.com/blog/post/ho...easy_level_sending_unit_is_changing_the_game/
68-70 b-body folks are still out of luck for a decent unit unfortunately.I have one from Vans in my charger and it works fine.
The install article I read didn’t require modification.Great if you don't mind extensive modification to a stock tank...
It mounts in the top of the tank.The install article I read didn’t require modification.
Got it - thanks for the clarification.It mounts in the top of the tank.
Our factory sending units....don't.
I just purchased a unit also , the one from Dante wasn’t accurate and could not be adjusted…I have one from Vans in my charger and it works fine.
Have? And results?Yea I have.
