mr_spock
Hi all, looking for some guidance. Car is a '66 Coronet with a 383 conversion (was a 318). Everything electrically worked, but the speedo had failed. I removed the cluster, replaced the speedo, put it all back. However, being an idiot, for the first time I forgot to check the ammeter wiring and connected the wires the wrong way round. Put the cluster back, hooked up the battery and FZZZZT there was smoke immediately. Disconnected the battery straight away. I'm confused as that shouldn't matter, the ammeter would just read backwards, right?
Pulled the cluster again to test. So far I've confirmed:
- Fusible link is fried
- Bulkhead connectors are all good, no sign of any damage, heat, smoke, melting or anything
- Everything in the cluster works so far, circuit board and instrument voltage regulator are fine, lights work etc. I have not tested the ammeter yet.
Note - I did not attempt to start the car, I didn't even turn on the key. It just blew immediately I connected the battery.
Now, I know it's a good idea to modify wiring in a few ways but right now I just want it to be a car again. So - what else should I check before replacing the link and trying again? They're $35 or so, don't want to experiment at that cost! The only thing I can see is that one of the ammeter posts seems a little loose. I have a spare.
Thanks!
Thanks!
