Garage Floor
Makes that YELLOW Roadrunner look even sweeter....very nice. :headbang: :headbang:
That is a great looking floor how strong is it ? Say if you drop a screw driver will it chip it up? I want to coat my floor but it's a "working" garage not for parking yet.
IMG_0637.jpgJust had mine done too,a lot less dust and so far seems to be indestructable .
Very Nice! It's great to have a clean, sealed shop floor. Mine is getting the normal wear with scuffs and scratches. I Might have to recoat in a year or so...
I sell a product called 100% solids epoxy. It is stronger than the concrete.It's a little tricky to apply as you have under an hour from when you mix the two components together to get it on the floor.Either you do it in sections or you have a lot of helpers, depending on the area you want to paint. You can get it at most Benjamin Moore Paint dealers. If they don't stock it, they can order it. It's under the Corotech label. It's not cheap, but it will last for a very long time.
Guessing some of the fancy floor guys don't do much welding or cutting with a torch? A floor like that wouldn't last a month at my place.
If you read entire post (which many, including you don't). I have two garages. One is dirty garage for welding, cutting machining etc. This is the showroom garage.
Very pretty.
I work a bunch in my shop. That'd look like a normal floor in a year.
My pretty garage floor does not see any welding or cuttting,but if I had to I could protect my pretty garage floor from that.
