superbee_68
I am selling because I plan to propose to my girlfriend soon and need money for an engagement ring. If I didn't need money for the ring, I wouldn't be selling most of this stuff. I am also selling my 1967 Belvedere, 1978 Dodge Ramcharger,1989 Rexhall/Airex 25 ft. Class A motorhome.
PM me for more pics or info. I will reply with my phone number.
Here's the list:
11" front drum brake setup complete from 69 GTX - $200
b-body 8.75" rear end, 741 open case, w/ 10" backing plates, good axles, unknown gears, will part out - $300
8.75" drop out, 742 case, sure grip, clutch style, 4.11 gears, new yoke, was pulled because pinion nut backed off 200 miles after rebuild, needs a new pinion nut at minimum- $400
Various cylinder heads - $100 a pair
Tons of thermoquads, rebuilt or use for parts - $30 each
Accessory drive, distributor, carb, intake, water pump, ps pump, alternator, etc. from 1966 383 4 barrel - $300
Accessory drive from 1972 400 - $200
440 cast cranks - $75 each
Various pulleys, bracket, water pump housing, connecting rods, covers, etc... -ask for price
big block 727 tranmission - $150
440 blocks, two available, believe they are 71 - $300 each
440 forged crank - $250
383 block, 1966 casting, w/ forged crank - $400
68 auto floor shifter parts, make offer
If you don't see it mentioned, I probably don't have one.
View attachment 177919View attachment 177920View attachment 177921
Here's the list:
