Did some appreciable searching here about gas gauge gremlins, not coming across my hassle, so posting for some tips in case anyone has encountered what I’m having. Trying to condense here: My gauge has operated intermittingly and seems to be accurate – when working. It seemed that it would work when started up for a while and goes near to or to empty after warm-up. It’s gotten worse where it usually isn’t working now. It’s a new tank and new rear harness, about five-years now. The temp gauge operates fine making me think it shouldn’t be the voltage limiter. I did have to repair the CB a few years back. Added an extra ground for the cluster.
Thinking it must be a grounding issue and jotted down some things to check while sifting through some posts here on the topic. Thought before I start the hunt, maybe someone has had this problem and can share what they found as the fix. Thanks!
