Gas tank
steve from staten island
8:45 AM
staten island,ny
Im getting ready to replace my sending unit with my newly rebuilt original. I ordered a new locking ring and rubber gasket to be on the safe side. Last time i put a new sending unit in before mounting tank i put some diesel fuel in and stood the tank on end to see if there was any leaks around the sending unit. Is this acceptable to do or am i damaging the unit. Thanks
Since diesel has a lower viscosity to gasoline, it won't be much of a leak test IMHO.
Use normal gasoline if you must test in this manner....but be careful not to smoke while performing these tests....we would hate to lose such a valuable Forum member. :D
Or you could just pressure test it...
That thing on the right picture is no daddy to made sure the tank doesn't bulge?
Haven't blown up an airplane wing yet and I've been doing this for 25 years... it only takes about 0.4 psi to inflate the condom and will show if the sender gasket is leaking.. or a supplier weld.
So if the condom has a hole in it ....does that mean your tank is Fu&%ed? :rofl:
Maybe, but there could be a little fuel cell in your future.
This is going to be fun.
I can envision Steve walking into the local Mom & Pop pharmacy and requesting one. "Yeah, i just need one condom, preferably one of those large ones so I can see what's going on. Oh, and not one of those lubricated ones, it might fly off."
Enjoy
The air test does work though, use soapy water mix to find leaks.
You actually want the lubricated as it helps seal it! Use a large elastic to secure it to the filler hole. I was just making sure the son's GF hadn't pin pricked his stock !! :)
Enjoy
I cant recall the last time i used one. I can just see explaining why i need to buy one.
"I cant recall the last time i used one"
Sorry to hear that my friend.
:rofl:
Seriously though the air teat is the best way to find pinholes, leaks.
Good luck
Reuse the old lock ring all the aftermarket one have issues. I sold over 100 nos rings trust me on this.
