Gauge cluster LED lights.....
'68 Charger
7:32 PM
Akron, Ohio
Curious if anyone has references/leads on gauge cluster LED lights. This is for the kind in the pic attached. I'm looking for either a LED bulb replacement or a LED bulb/socket combo replacement. These are the 3 bulbs/sockets on the circuit board for a '68 Charger.
Yes I've done the search and it's so overwhelming of the masses of different bulbs/colors/types etc. I already found LED replacements for the bayonet type bulbs for the '68 cluster.
Thanks in advance.:drinks:
Just do a search on eBay for 194 LED. I found the best results with white but it will be all down to personal preference. They're under a dollar each and usually come in packs of ten so you could experiment with color choices.
If you what a stock looking dash you will need 'Warm White' led bulbs. 'Cool white' bulbs will give you a noticeable blue shade to your cluster. I like the feebay ones. They are so cheap, so if you don't like em no big loss. I went thru 3 different types to find the ones I liked.
