where can I get those brass clips that hold the instrument pannel together? also are there any dirct fit electronic gauges that work with a ralley dash?
You mean the ones that attach the lens to the instrument cluster?
No, I do not believe there are simple "drop in replacement" aftermarket gauges. Charger Specialties does produce very nice electronic reproductions though.
yes,those are the ones I'm looking for. just got off the phone with charger spec., seems like a great bunch of guys, and their resonable. it'd be great to find drop ins that run off 12volts. vdo/autometer would have a nice market niche for classic cars
Lionized, big score, thanks for that link, they're exactly what I need
The VHX kit comes with everything you need to install it, but not drop in with your stock sensors and wiring by any means, pretty easy to do though, I installed their digital gauges in a 69 camaro they were straight forward and work perfect to this day, I know it sounds like a lot of money but for the b-body dash its just a bit more than a tic toc tach and a speedo...
I seen a set of gauges, new repops for $800, that was a tach(no clock), speedo, and the 4 small gauges, all new... The tic toc adds a couple hundred to that...
what exactly "fries" in the gauges?, what needs to be replaced when they spike?, they're so simple looking I'm looking at the temp/ fuel gauges they dont look burned or anything and an ohm meter showed continuity
