Gear swap
old guys rule
1:52 PM
Jacksonville, FL
Anyone out there know if there is a bearing available to fit an inch and 3/4 pinion and a 741 case?
Check with DrDiff. He has bearings and rebuild kits. I think the earlier ones were 1.800.
Your post sparked a memory.There used to be a company called Bearings Inc. If you have the correct inside diameter for the shaft and the race outside diameter they usually could come up with a bearing/race combo. It's been a long time,maybe the late 80's or early 90's that I was buying from them. Maybe still in business ?
