I still have the 3.54's in mine so I am guessing a gear change will be in order at some point. Will have to see what it is like on the road. Will send you a PM.
My two cents - I think a gear change is in order right away. I think you will be quite unhappy with the GV and 3.54s (and 3.91s too). Here's why.
As you identified, the 3.54 is reduced to 2.76 final. Great for cruising. Except:
1) what are your driving habits and style
2) what are your driving conditions (flat, rolling, mountains)
3) what is your tire height and cam power range
4) how do the three factors above come into play thru the complete driving spectrum you experience now and then expect in the future with the GV.
The 2.76 ratio gives you a shift point from 3rd to OD of 1500-1600 rpms (shift is at 45 mph for most applications). 1600 is at or below the power range of nearly all cams. You will be lugging on every shift. Or manually shifting so to not lug, and then what's the point of the automatic?
Three considerations - much taller tire, different cam, or taller gears (4.10 and up) (or a combo of all three).
I don't think you can put a tall enough tire in to compensate for the cam at 1600 rpm (my calulator showed that a 30 inch height still has a shift point below 2000). Do you want to change the cam (if needed)? Best option is the taller rear end gear.
The 3.91 yields a shift point at 1750, still low and "luggy". The 4.10s get you close to 2000 rpms and likely closer to the low end of the cam range.
The whole idea is to find the sweet spot in the 4-way combination of: tire, cam range, gear ratio, and the GV. Seems to me you want 4.10 or higher from the get-go. Or a cam that can match up to the 3.91s.
Food for thought. Dan.
