Question for those using GV under/over drive guys... I'm currently using the MSD shift controller that GV provided with a manual switch setup so that I can flip it on and off when I want, like I'm sure many of you are doing. However, there is a slight delay in the controller.... probably because it's making sure correct speed, direction, etc. All good stuff. But I'd like to have the shift instant. Today it takes a half second. That doesn't sound like a lot but I have to shift "early" so that it goes into and out of OD when I want it to. I have created a locking relay circuit so that it's a momentary on or off situation that goes directly to the solenoid on the GV OD.
With all that being said...
Question #1 - Installing a direct switch, bypassing the controller, is this common? Any issues I need to be aware of?
Question #2 - Do you have a better idea for a momentary switch for on and off as opposed to my locking relay setup?
Thanks in advance.
Thanks in advance.
