Going from 8 3/4 to Dana 60 9 3/4 drive shaft question
tallhair
Rufus "Mod-hair" Firefly
Staff member
2:12 PM
Mascoutah, Illinois
Hey guys I'm looking to change rear differentials in a 70 RR from a 8 3/4 to a Dana 60.
what is the difference in drive shaft length?
Any other things to consider (the Dana is coming out of a 69 B-body so spring perch etc dimensions are same there)
diff is coming with e-brake cable and is complete with 11" backing plates, brake mechs, drums, drums etc
PS if you have a nice original equipment Dana 60 3.54 ring and pinion gear set please PM me!
Just did it... cut the shaft 1" I had already shortened it for a Gear Vendor OD and may have been a little on the short side already. Check the U joint, I did it on a 64 and will be using one of the two different sized u joints, Picked it up today will be installing sat am. everything else you have should be the same.
I ran across this awhile back but make no claims as to it's accuracy. YMMV
Here is some info:
This is a chart of common 1966 and later RWD Mopar slip yokedriveshafts. It is sorted by length to help with interchange.
Mopar Slip Yoke Driveshafts PartNo Years Dia" Length" Trans Rear Engine Body
2883775 1970-71 3.25 42.60 727,833 9-3/4 426 440 Barracuda Coronet
2996134 1974 3.25 43.29 727,833 8-1/4 318 360 Barracuda
2883636 1970 3.25 43.60 727 8-3/4 383 426 440 Barracuda Coronet
2996134 1971 3.25 43.79 727/833 8-3/4 340 Barracuda
2883769 1970-71 3.25 43185 727/833 8-3/4 340 Barracuda
2883667 1970-71 3.25 44.60 727/833 9-3/4 426 440 Challenger Coronet
2883690 1970-72 3.00 44.99 727 8-3/4 340 Duster Demon
2883656 1970-71 3.25 45.60 727/833 8-3/4 340 383 440 Challenger
2996142 1971 3.25 45.79 727 8-3/4 340 383-2 Challenger
2883782 1970 3.25 45.85 727/833 8-3/4 340 Challenger
3578138 1974 3.00 47.40 904/230 8-1/4 318 Barracuda
2852228 1967-69 3.25 47.81 727 8-3/4 340 383 Dart
2883693 1970 3.25 47.99 727 8-3/4 340 Dart
2852206 1967-69 2.75 48.60 904 8-3/4 273 318 Barracuda Valiant
2852206 1967-69 2.75 48.60 833 8-3/4 273 318 340 383 Barracuda Valiant
2852216 1968-69 3.00 48.88 727 8-3/4 340 393 Barracuda
2996157 1972 3.25 48.89 904/230 8-3/4 225 318 Duster Demon
2883760 1970-72 2.75 48.96 833 8-3/4 340 Duster Demon
2883760 1970-72 2.75 48.96 904 8-3/4 198 225 318 Duster Demon
2883752 1971 2.75 49.27 904/833 8-3/4 198 225 318 340 Valiant
3578146 1973 3.00 49.40 727/833 8-3/4 318 340 Challenger
2996105 1971 3.25 49.50 727/833 9-3/4 426 440 Belvedere Coronet
2781952 1966 2.75 49.58 904/833 8-3/4 170 225 225 273 Barracuda Valiant
2996146 1971-73 3.25 49.89 727/833 8-3/4 318 340 Challenger
3467151 1973-76 3.25 49.90 904/833 8-1/4 225 318 340 360 Duster Dart Sport
2883779 1970-72 3.25 49.95 727 8-3/4 318 Challenger
2883766 1970 3.25 50.18 727 7-1/4 225 318 Barracuda
2781955 1966-67 3.00 50.27 833 9-3/4 426 Belvedere Coronet
2853247 1968-69 3.00 50.39 833 9-3/4 426 440 Belvedere
2996101 1971 3.25 50.68 727/833 8-3/4 383 426 440 Belvedere Coronet
2996109 1972-73 3.25 50.80 727/833 8-3/4 400 440 Belvedere Coronet
2852326 1968 3.00 50.96 833 9-3/4 426 440 Coronet Charger
2660628 1967 2.75 51.03 727 8-3/4 225 318 383 Belvedere
2781953 1967 2.75 51.15 727/833 8-3/4 426 440 Belvedere Coronet Charger
2660628 1966-67 2.75 51.28 745 8-3/4 225 273 318 383 Belvedere Coronet Charger
2996268 1974 3.25 51.34 727/833 9-1/4 360 400 440 Belvedere Coronet
2781953 1966 3.00 51.40 727/833 8-3/4 426 Belvedere Coronet Charger
2533192 1967-69 2.75 51.43 904/833 7-1/4 225 273 318 Barracuda Valiant
2852161 1968-69 3.00 51.50 727/833 8-3/4 383 426 440 Belvedere
2852212 1967-69 3.00 51.53 833 8-3/4 273 318 340 383 Dart
2996137 1973-76 3.25 51.89 904/833/230 8-1/4 225 318 340 360 Duster Dart Sport
2883758 1972 3.00 51.96 904/230 8-3/4 225 318 340 Dart
2660635 1967-68 2.75 52.00 727 8-3/4 318 383 Belvedere Coronet Charger
2852162 1968 3.00 52.07 727/833 8-3/4 383 426 440 Coronet Charger
2852118 1967 3.25 52.27 727 8-3/4 440 Charger
2660635 1966-67 2.75 52.28 727/833 8-3/4 361 383 426 Belvedere Coronet Charger
3467155 1973-76 3.25 52.70 904/833/230 8-1/4 225 318 340 360 Duster Dart Sport
2883696 1971-74 3.25 53.18 727/833 8-3/4 225 318 340 360 400 440 Belvedere Coronet
2996113 1974 3.25 53.30 727/833 8-1/4 400 Belvedere Coronet
2996195 1970 3.25 53.64 727 8-3/4 383 440 Belvedere
3578322 1974 3.25 53.80 727/833 8-1/4 400 Belvedere Coronet
3578331 1974 3.25 53.84 727/833 9-1/4 400 440 Belvedere
2853237 1967-76 3.00 54.36 904 7-1/4 170 225 273 318 Dart
2660622 1966 3.00 54.54 904/833 7-1/4 273 Valiant
2996201 1971-73 3.25 54.86 727/833 8-3/4 318 Belvedere Coronet
3578301 1974 3.25 54.92 727/833 8-3/4 225 318 Belvedere
2533148 1966 2.75 55.42 727/833 8-3/4 225 273 318 Belvedere Coronet Charger
2660550 1968-69 3.00 56.17 904 8-3/4 225 273 318 Coronet Charger
2660550 1966 2.75 56.42 904/903 8-3/4 225 273 318 Belvedere Coronet Charger
2660607 1966 3.00 56.61 904/833 7-1/4 170 225 273 Dart
2883735 1972-73 3.25 57.36 727/833 8-3/4 225 318 Belvedere Coronet
2996121 1972 3.00 57.42 727/833 8-3/4 225 318 Belvedere Coronet
2852253 1968-69 3.00 57.65 904/903 7-1/4 225 273 Belvedere Coronet
2996121 1974 3.00 57.82 727/833 9-1/4 360 Belvedere Coronet
2852222 1968 3.25 57.93 727 8-3/4 383 440 Chrysler
And yet another
This chart is kinda goofy. Page 3 should be to the left of page 1 so you can match the model/ engine combo to the prop shaft.
http://users.eastlink.ca/~imackinnon/driveshaft.pdf
Yes, you need to be 1" shorter + or - 1/8" or so but it's always best to do an actual measurement to be sure. And those charts are a good guide imo because production tolerances were never on the money. If the engine was sitting back 1/4" from what it was supposed to be and if the rear end was sitting forward 1/4" (I've seen it), then you can be 1/2" too long so do the measurements.
