Roadrage
- 6:36 AM
- Oct 11, 2013
- Treasure coast florida
Need some help or clarification please.
Trying to get my 66 charger on the road, have been starting the car in the garage for friends and family and everything was going great. Just trying to keep motivated to finish the car and started driving it around the block, short runs and everything seems fine. Then got the bright idea to drive it to the gas station. Ran good 3 miles only to the station. Fill her up with high test, everyone at the gas station freaking out that they had never seen one of these cars before, 10 minutes go by and try to start the car and battery sounds like it is dead. DUMMY.... Now everyone scatters like the car has the plague, that sucks... Not so dumb after all, had my son come up and jump the car, took a long time but got it running.
Now I remembered that I never hooked a ground up from the motor to the frame....
Here is what I have.... Not an original car first off.
Red top optima battery in the trunk, one awg wire from there to the front. Ground on a welded post in the trunk to the frame. Frame has welded square 2x3 from the subframe connectors to the body, all tied in. That is where the cage is welded to the frame, everything is solid.
Other posts say that the right side of the head needs to be grounded to the body, are they suggesting back header bolt to the frame, or body. Mine should be all tied in correct?
Just need clarification on specific locations I should be grounding the car to......thanks in advance.
