Guessing game. what Mopar does this fit?
monaco66coupe
6:57 AM
Omaha
I got it along with a group of parts. The transmission case hole is just a hair under seven Inches in diameter. Aluminum case by the way, and no part number. It fits perfectly on the 383-440 block.
My guess is a pre torque flite automatic trans. I forget what they call them, doe it have cooling vents in the side, or it might be a early truck creeper gear trans.
I thought of that, but It is aluminum. I have an original 1956 powerflite transmission sitting here as well, that weighs four bazillion pounds. This bellhousing is as light as a feather. Anybody?
With a hole that big in the center can't believe its a stick shift. If its magnesium ??
Is it for a Marine out drive for a boat ?
Bombardier twin tracker, 1954, chrysler straight 6....
Looks kinda like the early hemi bellhousings, aluminum started in 61 or 62 I thought...maybe it's an aftermarket piece?
Okay...It is industrial! Maybe it is for a huge water pump?
I got it along with a group of parts. The transmission case hole is just a hair under seven Inches in diameter. Aluminum case by the way, and no part number. It fits perfectly on the 383-440 block.View attachment 398092
I would tell you, if you would answer my Personal message- conversation messages........................8-)...................MO
I see no mounting boss for clutch linkage. I stand by by guess that it is some type of adapter to power something NON automotive. A water pump, a generator, a boat out drive...
without more pics, I can't tell if it has provisions for a cluch fork...........................MO
WTF ?????Did the OP fall asleep ???
HELLO ?????
What happened? What is the correct answer ????????
Hey Kern,
I actually don't know! I am hoping someone here does. It was with a pile of bell housings I acquired, and have been searching for any kind of number anywhere.
Nothing! It definitely fits the 383-440 block. I would ask the previous owner, but he is dead! There is a Inspection cover that goes with it that covers a square slot, but nothing else, no clues,nothing. The transmission bolt holes are further apart than normal. Maybe a four wheel drive unit?
