H e l p ! ! ! ! The vans got gremlins
SPEEDYRT1
1:27 PM
alexandria MINNESOTA
H E L P 1996 DODGE grand caravan have replaced the cam @ crankshaft sensor ,fuelpump ,coil pack, both the auto shutdown @ fuel pump relays test drive yesterday died , no start, cranks over got home , let sit 12 hours fired right up , slammed the drivers door or the hood it dies , cranks over , no start , any advice, or observations or similar problem would be greatly appreciated also will a 96 3.3 trans fit the 2001 3.8 town@country ? trans mission kicks out of overdrive after it warms up @ sometimes stalls as u comes up to a stop, feels like the torque converter isn't kicking out of lock up mode , any ideas ? thanks
What don't you have when it does not start? Fuel or spark? If it shuts off when the hood is slammed I would say you have a wiring issue. Either s loose wire going open or chaffed and shorting to ground.
yes , that could b but where do i begin , when it was running i wiggled every fuse @ relay in the command center ,under hood ,@ the wires ,from cam @ crank sensor , the purge valve , nothing ,it stayed running , got me bafilled ? thanks ! !
Begin by seeing what you don't have. Fuel or spark. Either pull a plug wire and check for spark, or give it a shot of carb cleaner and see if it fires. Once we figure that out we can narrow it down from there.
Do you have any way to read codes? And just for the hell of it, get that thing rinning and warmed up, then tap on the pcm with a mallet. Not hard. Don't try and smash it, but give it a few taps. See if that makes it stall.
i did the check at the asd relay pulled out @ got juice at 2 points ,then pluged it back in, pulled fuel pump relay got juice , @ under crank mode , plugged in , fired up tapped the pcm @ the fuse block , taped @ wiggled everything under hood a ok stayed running crawl under dash there,s a box thin blk with about 6 or 8 wires going to it .wiggled it ,died , wiggled it while cranking it fired up , dropped the hammer on t floor, it died,it is mounted out from firewall on steel plate above steer colium , b c m ? or what ?
The bcm mounts behind the junction block. On the back of it. not sure what you are seeing. Can you post a picture. That may help
i think it's the f ";." astro start unit that,s about five years old m-a-a-n what a pain , well now i know thank,s for your help ! ! !
hey that box under dash is the A B S controller , disconnect batt removed box @ plug , pins were nice and shiny the plug looked good no mold or rust , re installed it hooked up batt, fired right up , beat , banged ,wiggled , jigled , every wire ,@ unit i could see , under t dash , slammed t door 3 -4 times , slamed the hood twice , nothing hapend , it stayed running , test drove it ,hit every bump in t road i could , hit the railroad tracks twice , it stayed running, damned if i know ,found the auto start box , did the same to that as everything else its still running , w i e r d
