SOLD Head bracket for 440
5.7 hemi
12:21 PM
TEXAS
Feedback: +12 / =0 / -0
I need the piece of steel that has 3 holes, 2 are used to bolt to the head and the 3rd is for the long alternator bolt. Not sure what that piece is called exactly, but nonetheless, I need it. Let me know how much. Thanks!!!
They don't make the steel piece that bolts to the passenger side head.
Per post #2.. the 2nd item down on the list is what you need($18). Plus a spacer or two & the bolts. Nothing actually bolts to the head just the long alt. bolt.
Oops, I made a mistake. The rectangular piece that goes on a 383.
The rectangular piece with the 2 bolts that go on the front of the passenger side head.
I have a head bracket (see pics). Yes these are for the 383s. It's purpose is to position the threaded hole in the same position as the one on a 440 RH head for the long alt bolt.
PM me if you're interested.
I`ve got the 2 part set-chrome, that I couldn`t use. ( have motor plate). If ur interested. can send phone pics.
Got one coming from Crank, thanks man! Thanks to all who offered.
I bought Derwud's "CVF Beast" set up and he has an rb block. I have a b bloc, and j called CVF and they said the bracket on the alternator was different between the 2 blocks. So by getting this piece, it should bolt on without issue or maybe just need to shorten a spacer.
Yea it was designed to make up the 1" height difference between the two blocks instead of Chrysler having to make two different bracket setups saving on production cost.
So I've been told lol.
