- 6:56 AM
- Apr 13, 2012
- Granite Bay CA
I am nearing completion of several interior upgrades and I'd really like to get the heater and A/C system to work. I've had the Charger since March of 2000 and in all this time, the heater has never worked. I haven't really cared all that much since the car is primarily a 3 season driver anyway.
The car is a 1970 Charger with factory A/C. I'd actually prefer that it were not an A/C setup but it is. The plastic electric/vacuum switch was so stiff, the push button keys barely could move. I replaced the switch while I was doing the wiring changes and the new guage installation. The keys all move freely now. I get no power to the switch though. On the engine side, the fan does not get power either. If I disconnect the wire leading to the fan motor and add a jumper wire to it, the fan will spin. I have a FSM to trace that wire but I was hoping to get some insight as to why the fan may not be getting power if all the wiring associated to it is unmolested. Is there a relay that is troublesome? If so, where is it?
I need to run a vacuum line from the engine to the small storage can for the A/C operation. Is it likely that the electric/vacuum switch needs a vacuum signal to allow the fan to energize? Sorry to sound like an idiot here, I'm trying to learn more about electrical systems and can really benefit from the help!
