70B
Let me start by saying I've got a 70' SuperBee and it's a work in progress, but I'll bet that's a familiar story. Interior is complete but is going to be changed from a bench seat to buckets. Body is 100% done, other exterior is 95% done. Motor is a 383 with future work planned. Four speed needs 2nd gear work. Suspension in rear has new leafs on it, sway bar and air shocks. Front end has new sway bar and shocks, disk brake conversion, uni-steer rack and pinion, new torsion bars, Hotchkis upper A arms. But I have a PROBLEM.
I have the front end from hades. Every time it's aligned and I then roll forward and the front is out of alignment within 50 feet of moving forward by about a 1 1/2inchs, then the wheels go back straight again when I backup. I can not keep it going straight with any mods done! I'm contemplating a AlterK front end, or the Magnum Force? But my question is, is this necessary? This doesn't make sense. My troubles started with a uni-steer rack&pinion and have only gotten worse and undriveable, the rack and pinion is going back. Any ideas why this is happening and what can fix it?
While I'm at it......how do you upload a photo, going up to add an image isn't working?
