Hello
Grenmopar1!
New Member
2:32 PM
canada
Hi, thank you for letting me join this group. I have a 1970 satellite built as a road runner tribute. I haven’t been able to get the front signal lights in the bumper to work correctly. Whether I put the left signal on or the right signal on, both of lights blink yet the rear tail lights work correctly. Also the signal indicator lights in the dash do not blink period. Any thoughts on the issue might be. Thanks.
Wow , great looking car, welcome.
My guess is to get a FSM and go thru the steering Colom wiring... or just pull the wheel and replace the old turn signal wiring unit.
Search here on the form for Ideas and help. :thumbsup:
Welcome from the central coast of Cal, EH! You most likely have some ground issues too.
Welcome to FBBO from Canada, also (Ontario). Nice Plymouth. If the turn signal has been replaced at any time, make sure that the different coloured wires from the switch are in the correct cavities of the plastic connector. Thanks for your picture.
Okay, thanks I will check out the connector
Welcome aboard from Ohio. (Make sure your grounds are good at front end)
Welcome to the site! Btw, we have a great technical forum too....
Welcome to FBBO from Georgia.
Nice car, I like the color
