HELP: data plate decode 1970 Roadrunner
FASTEDDIE1960
6:53 AM
iowa
I have found most of my codes for the data plate on my 1970 Roadrunner but having trouble finding these last few.
088
L2X9
TX9
688
any help greatly appreciated. thanks
Can you show the tag, you either have some wrong codes there. Or a Lynch road tag so we need to see where they are placed.
L2 X9 is I terir trim code for low level black vinyl bench seat
TX9 is for paint. One of three parts of the car depending on where on the tag it is located.
The O88 might be V88, stripe delete across the top of the trunk
088 could be the engine code, 1970 383, 335 hp. L2X9 is the interior code. Black vinyl bench seat. TX9 could be black upper door frame paint. If 688 is actually 668 then it could be the trans code, 1970 383-4 torqueflite
thanks, yes it is a lynch road car here are photos of data plate..thanks again
The TX9 is black upper door paint.
Looks like M2X9, not L2X9? That is your interior code.
Just change the phrase could be, in post number 4 to is, and you are good to go. You also have a 3.23 standard axle with 11" drum brakes.
thanks
