Help - need to know these part numbers.
Hilljack68
3:40 AM
Ohio
I don't have a parts manual for my 68 Coronet 2dr hardtop, so can anyone help me out with this picture? I need to know the part numbers for items 16, 17 and 19. My SM doesn't break it down far enough, but I found this pic on another forum. It shows the parts, but not the part numbers. Thanks fellas!
...and where on earth would I find them??
Looks like it's just the "mylar" style felt, the plastic guides and the steel joiner pins for the front of the door glass / back side of the vent window track..
Richard is your man... @69bfan to help you find some correct CURVED OEM felts. Don't even try to use the repro junk.
Read some restoration threads, these have been covered a 100 times there!
+ Click to Expand
MN3104 - 1968-74 A-Body; 1966-70 B-Body Front Door Glass Channel Seals
Reproduction front door glass channels for 1968-74 A-Body and 1966-70 B-Body models. These seals attach to the front of each door window in order to allow the glass to slide up and down within the vent window frame. Includes four slider clips and two p ins per side. Sold in pairs.
Note: Seals will not work on new glass, these are for original glass only
Classics really covering their *** here. "won't work for new glass..only for original glass". Give me a f'n break.
Typical of classic.....then will come here saying, “we are not aware”, “send us pics so we can work with the manufacturer”
As you stated Wayne the NOS seals are the only way to go....if you can find a pair....Not cheap but worth it
Darrell, I responded to your email. The factory part number is 2932230. They have been on the NS1 list for over two years now and years ago, they would come and go with availability from Chrysler as they was used up to 1993.
At this time, I do not foresee Chrysler bringing them back into production. Be very cautious about buying these pieces as vendors will use the reproduction part number CHRY32230, leading you to believe that your purchasing the NOS seals. I would only purchase them if the were still packaged in the original package.
If you find a set of the real seals, expect to pay $350 to $600 for a pair of them if the buyer know what he has. You may luck into a single or a pair if your patient, but they are almost impossible to find. If you know what your looking at, you can detect the difference between the two.
The reproductions are usable , but super fragile. I recommend having two people to assist with the installation and use your old ones as a guide for the pin placement. Also, cut the reproduction pieces slightly shorter than the originals.
As stated in the Classic ad, some of the reproduction glass is much wavier than the original glass. This will cause the channel liner to bind up and then tear. At basically $45 to $50 per piece, plus a tedious job to do, it is not something to be done over.
