Help With ID splash guards and misc pieces
Stowe
1:10 PM
NY
Hello,
In the process of putting my 66 back together. I didn't take it apart and I am trying to figure out where some splash shields go and help ID some parts. I have the splash shield kit . I need help with the location of the 2 large shields in the middle and the 2 thin shields in the top of the picture. Also need information on the location of the 2 larger rectangular shields and the 2 smaller shields with the 90* edge on them. Are there any gaskets that go onto the 2 large front shields. Are there any diagrams available for reference? Thanks
I've recently restored the front splash shields (fore and aft), hopefully I can help.
The two shield gaskets in the middle are installed on the top of the aft (long) shield. These are available as a solid gasket like yours or a 'C' type like mine. As you can see in my before and after photo, mine were originally the 'C' type, hence my choice. Those pieces also require the edge gasket which I don't see in your gasket set.
The gaskets on top of your set are installed on the fore (headlight guard) shields in the front fender area. I don't
see the metal splash shields in your photo.
Cheers! Tom
Thanks Tom,
Would you happen to have a picture of the metal splash shields you said was missing from the picture? Also, can you help me with the location of the metal shields circled in the picture. I don't see them in my manual. Thanks
Thanks Tom,
The 2 top circled go on the top of the bumper brackets
The 2 lower ones bolt to the bottom of the frame rail by the strut rods.
I actually sent DMT the original format for the splash shield rubbers years ago.
See if I can get a pic of them on one of my parts cars
The fore (headlight) shields...before and after restoration. Installed in front area of fender.
View attachment 1510884View attachment 1510885
Cheers! Tom
Hello Tom,
Were did you source the edge gasket you mentioned above. I do not see it on any kit . Thanks
