Help with rusty fender tag
dspur
6:01 PM
Albertville, AL
This fender tag is very rusty and some of it hard to make out. Any help with what those likely are would be appreciated.
V1X V8X Y16 26 END
A62 H51 L31 M21 N85 R11
B7 B7 H2B B7 205 342846
E63 D21 WM23 H9G 215149
On the second line from the bottom the 3rd code from right appears to be H2B and the only return I would get on the decoders is “Upper Door Frame; Unknown at this time” Could be M2B but nothing pops on that that I can find.
On the bottom line fourth code from the right appears to be H92, though this part is so rusty. H9G followed by the other numbers match the VIN, which is WM23H9G215149 So I assume it is H9G which is
H = 383 330HP or 335 HP 4 barrel (mine is the 330hp)
9 = 1969
G = St. Louis
Lastly, the “B7” is the third one on that line and the third one shows up as follows:
B = B Class (I assume for B body?)
7 = Cloth and Vinyl 50/50 Bench Seat (mine is bench but not split 50/50, though it could have been changed. It did have some very ugly cloth velour for which I am going back with the dark and light blue from Legendary. This also did not have headrest, and given it appears to have been built in February could that be correct? I understand that somewhere in that time frame the head rests became mandatory.
Any interpretation, corrections or comments are welcome. I want to be sure as this is all numbers matching and I am going back very close to original on most items, except for the hood, original was probably a bubble hood but has been changed to an N96 without the underneath stuff, will not fit due to AC compressor etc. and I will likely leave off the vinyl top because it looks so good without it.
I have the correct interpretation for all of the other codes.
TIA
H2B=High trim grade vinyl bench light blue interior
B7=Dark Blue upper door frame color
WM23:
Dodge Coronet,Charger
Medium, Super Bee
2 Door Hardtop
H9G: 383 330HP OR 335HP 1-4BBL 8 CYL
1969
St. Louis, MO, USA
215149: Sequence number
E63: 383 cid 4 barrel V8 High Performance
D21: 4 Speed Manual Transmission
B7: Medium Blue Metallic (Dodge), Jamaica Blue Metallic (Plymouth), Jubilee Blue Metallic (Chrysler) Exterior Color
H2B: Trim - High, Vinyl Bench Seat, Blue
B7: Medium Blue Metallic (Dodge), Jamaica Blue Metallic (Plymouth), Jubilee Blue Metallic (Chrysler) Int. Door Frames
205: Build Date: February 05
342846: Order number
A62: Rallye Instrument Cluster Package
H51: Air Conditioning with Heater
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
N85: Tachometer
R11: Radio Solid State AM (2 Watts)
V1X: Full Vinyl Top, Black
V8X: Tranverse Stripes, Black
Y16: Sales Bank
26: 26in Radiator
END: End of Sales Codes
