hemi 540 fuel pump
steve maluk
9:00 PM
johnson city tn
hello gang
need a good mechanical fuel pump for my 540 hemi cross ram 770 carbs one that might look like it belongs on a mopar
street use any suggestions' thanks
Carter strip super pump is the one I went with, you will have to use a good dead head fuel pressure regulator and gauge.
I had a carter street super pump on my hemi. It didn’t seem to be able to supply enough fuel to the motor. I switched to an electric pump and problem solved.
I run the fuel through the old mechanical pump so it looks stock.
If you can find a Clay Smith pump you won't go wrong. They are based on the old Nascar pumps and will supply enough fuel for 1000hp. They do frequently need a little clearancing to get them to fit but 5 minutes with a hand file gets it done. They have an alcohol-proof diaphragm so work with today's crap gas.
