Hemi valve lash
moparmarks
I'm just a guy with a screwdriver.
7:49 AM
Western Colorado High Desert
Have a Hemi with this mechinal roller cam.
Lift in .651 ex. .664
Dur. @.050 in. 273.25 ex. 279
Lobe center 114* installed 108*
What should I set the lash at for both cold and hot?
The blue print sheet says in .016 ex .020 but don't know if that is for hot or cold. Checking where it is at now cold it is much tighter.
Many thanks.
With heat everything expands, so my guess is that the cam specs are the cold numbers.
I've never seen a Hemi cam spec cold. You must assume that is hot. With aluminum heads you can set it .007" tighter cold and that will get you close. I haven't put anything together with iron heads in so long I don't know, maybe .004" tighter.
My cam card just for reference
But mine is solid lifters
But I cant imagine this specs is for a hot engine
Are your heads steel or aluminum? Makes a big difference on aluminum head big block Chevies so it might on a Hemis too?
From what I know and have seen over the years camshaft manufacturers always specify HOT lash settings.
The lash obviously needs to be correct when the engine is hot.
Like Rick said if you want to set them cold depending on head material etc you reduce the gap used.
I will usually warm up the engine and take a valve cover off and check a couple of cylinders to ensure the cold setting was close.
I do them cold from there and look for any big changes in lash - no big changes all good.
I agree, need to find the hot setting, then figure out cold, and use it from there. I imagine trying to get to the valves before they cool off in a hemi would be " un fun"
Another way I have done it on an already running engine.
Warm the engine up and set the hot lash on number 1 cylinder.
Don't move the engine and allow to cool until the next day.
Measure the cold lash and set the rest to this setting.
Takes a bit of time but it appears to work OK. A thousandth tight or lose does not seem to make a lot of difference to power IMO.
Aluminum heads grow more than steel heads and valve train parts with heat. Thus clearances may well open up when hot. No idea how much on a Hemi. An old Chevy Engineer said the Chevy Power Manual said to set clearances with aluminum heads at .010” tighter than specified hot lash. But that’s for a Chevy. I would either consult the cam manufacturer or do as Steve340 described to figure it out by experimentation on one cylinder.
Thanks for all the input
I had to replace 3 push rods and adjusters due to an oiling issue so I'm starting out cold.
I'm sending an email to Kenny at Indy.
Many thanks.
----------------------.006 tighter on a cold engine ...
I'd pick a safe loose number, and set them to that cold.
Then, warm the motor, pull a cover and see where they went .
That will tell youhow much they move, and In which direction. That gives you the info to set them cold to reach the setting you want when hot.
Cam cards are alway the hot numbers. Around .005" tighter than the spec cold will get you close. Then check one bank hot. Record the numbers. Let it cool overnight. Check that same bank again and do the math. Exhaust and intake may be a different amount of expansion. Once you know the expansion dimension you'll never have to mess with them hot again. With a mechanical roller you need to check them often. My racecar gets checked every 20 passes. A street car I'd check once a month.
alum. heads -.006 , cast iron .004 ....
On a stand, Not real bad.
In a car ,,,not fun ,,,or fast
Not horrible on the right side but at best will be a warm setting, not hot. Messy method would be to pull the right valvecover, put a cardboard U-dam on the bottom, install tubes and sparkplugs and run it a bit. I would just experiment with cold lash instead I think. I never had problems over the years setting them .004 tighter cold. Sometimes knowing more isn't a good thing.
