Hi Comp Water or Ethanol ?
1962polara
6:28 PM
Australia
I thought best to start this specific thread.
I'm tossin up what to do to run my 13.5 compession Max Wedge engine.I'd like it to be as original stock factory
As some advised Methanol/Water is an option and will keep it original the best.I've read you can either inject pre carb OR after carb.There was an article in Chrysler Power Magazine..Its very intersting
http://www.snowperformance.net/product_images/magazine_article-pdf-130.pdf
Alternatively what would need to be done to run E85? (fuel line,pump,carb ect...).
thanks
Are you running the engine now? If so, how does it handle 92 octane?
I have 75cc Heads and -12.1 cc, .140" Domed pistons with a .039" gasket. I can run on 92 octane! It will run on when shutting it down if the idle is at all high, but if I notice this condition I can shut it off in gear.
It has NO run-on with 100 octane low lead Av Gas.....
