Hi from a new member
Daddeekul
New Member
6:55 AM
Lincoln, CA
My screen name is Daddeekul. I am the proud owner of a REAL 1969 Dodge Super Bee. Was originally 383 - 4 speed car. Now due to knee surgery is 472 - auto.
Have question, need advice. Looking for a quality MOPAR shop in Sacramento, CA area to fix my run hot problem. I believe I have a restriction in the block/heads. Have had heads off, found nothing.
I have a custom BE Cool radiator with twin electric fans, external trans cooler and 160 degree Milodon thermostadt.
HELP!
Mark
MOPAR OR NO CAR!!!
Welcome to the site! Great car :)
Mike
Welcome! Im sure someone here has the answer or can point you in the right direction.
Mark welcome to FBBO, from a fellow NorCal member...
post you questions in the general forum you will get far more responses to what your asking, be very specific, give details= what camshaft ??, what ignition timing ??, what carb & what changes, jets etc ??, what bore size ??, what compression ratio ??, what heads & size of combustion chamber etc. ??, what head gasket & thickness ??, what size/style Be-Cool radiator ??, what cfm are the fans ??, what type of temp. gauges used ?? etc., anything that could maybe pertain/cause to the over heating problem see ya I'm done
Welcome aboard, From the eastern part of the country!
