Hi from a new member
Daddeekul
New Member
7:38 PM
Lincoln, CA
My screen name is Daddeekul. I am the proud owner of a REAL 1969 Dodge Super Bee. Was originally 383 - 4 speed car. Now due to knee surgery is 472 - auto.
Have question, need advice. Looking for a quality MOPAR shop in Sacramento, CA area to fix my run hot problem. I believe I have a restriction in the block/heads. Have had heads off, found nothing.
I have a custom BE Cool radiator with twin electric fans, external trans cooler and 160 degree Milodon thermostadt.
HELP!
Mark
MOPAR OR NO CAR!!!
Welcome! Im sure someone here has the answer or can point you in the right direction.
Mark welcome to FBBO, from a fellow NorCal member...
post you questions in the general forum you will get far more responses to what your asking, be very specific, give details= what camshaft ??, what ignition timing ??, what carb & what changes, jets etc ??, what bore size ??, what compression ratio ??, what heads & size of combustion chamber etc. ??, what head gasket & thickness ??, what size/style Be-Cool radiator ??, what cfm are the fans ??, what type of temp. gauges used ?? etc., anything that could maybe pertain/cause to the over heating problem see ya I'm done
Welcome aboard, From the eastern part of the country!
