Ranger16
I'd check that Tach. When I installed my Sun Super II, I forgot to check the switch and got the same surprise you did. Switched it to 8 cyl. and all was well.
You know I had forgot about this possibility. As a kid doing my 1st clutch job I flipped the shift leversAny way your shifter rods are in the wrong holes on shifter or are on trans wrong?
Down load a speedo app to your cell phone and see what it says. You need to verify the speedo first. After that its just a matter of doing the math.
Randy, your math seems off a bit too though.As already stated either the tach or speedometer is off. My Chevelle had 4.88 gears and didn't turn 4k at 60mph. If I recall correctly it was mid 3k's at that speed. If you're clutch was slipping that bad(and you didn't notice) you would have been informed by the fire department or been on a flatbed by now.
Well, the speedometer and tach are both crap.
Installed a new tach, and used an app for vehicle speed
60mph @2750ish RPMs. Just what it is supposed to be. I guess that is what happens when you havent driven a real (mopar) car in years, you forget what they are supposed to sound like.
All is well again with the universe.
Dale
SW MI
I just checked one of those gear calculators. It says 3514rpm. 28" tire, 60mph, 4.88 gear, with a 1:1 4speed. Maybe you've got a little bit of convertor slip. A couple hundred rpms isn't uncommon.Randy, your math seems off a bit too though.
I have 3.55s in my Charger with 28" tires and at 60, I am running around 3000 rpms.
As has been mentioned already......
First step should be to verify the rear gearing.
“If” those are determined to actually be 3.54’s, the tac is off(or you have really really short tires).
For example: 60mph, 3.54’s, 26” tires = 2745rpm driveshaft speed.
On the other hand......
60mph, 4.56’s, 26” tires = 3536rpm
And 4.88’s would be 3785rpm.
Likely your 3.54 gears are more like 4.56.
Probably didn't change the little stamped tag.
What size rear tire u running?example- i have 354 dana 4 speed-70 miles a hour is 3400
I have the same drivetrain, and no way can I 'easily take off in 3rd gear".So, new to me '69 GTX conv, 440, 4-speed, Dana rear with 3.54 gears, 15 inch tires all around. Driving to the gas station today, and to the local body shop, I was seeing approx 4000 RPM @ 60 mph in 4th. I can easily take off at a stop sign in 3rd.
Just the way it is? Could someone have re-geared the 4-speed (is that even possible)?
Dale
SW MI
